Can I just confirm, it was running prime at 45C with 1.7V running through it!? Just kinda hard to believe haha, 32nm manufacturing is definately impressive leap forward if so!
i think 4ghz on a stock cooler is doable... in fact im going to try it now
I have to admit rjkoneill, those are pretty tasty speeds =)
One question, on some of the OCs you have the CPU voltage up at 1.6-1.7v, which would be considered a suicide voltage, and would (eventually) kill the CPU . My cpu (sig) is only running 1.45v. What sort of voltages can you put through those things without killing em?
are the features on the asus formula 3 worth it over the other asus boards in that range ? the gene is a bit cheaper and its only lacking a couple of things as far as i can see, and looking further down the list there is the Asus P7P55D? £50 cheaper than the formula 3 ?
What features are important to you specifically?
You got an email rjkoneill.
