- 20 Dec 2010
- Lincolnshire
Cheers will have a look.Check these guys out international decorative surfaces as they do both the laminated and pvc panels plus they have branches nationally.
I tiled my bathroom about 5 years ago and I am still happy with the result - However on shower corner the corner isn't 90 degree so shower tray had a bit of a gap at each end - not in corner - I was plagued with a small leak so last September ripped shower out and put up two shower panels - They are travatine colour and fit fine - I had one 1200 x 2.2m and short side 900 x 2.2m
Put long side on first then butt short side up to it - It took a week for me to stick spacers onto tiles to make sure the boards sat square - was worth the work as fit was perfect - Put a new minimal shower cubicle up and works and look fine - Total cost for boards and trim was around £350
Boards are marine ply and 11mm thick
I polish boards with car polish and water just runs off and I also use a Karcher to clear remaining water off then dry with car drying towel.
By way - I looked at those plastic tiles/boards/strips and reminded me of wall covering in loo at Morrisons.
We used them in our bathroom refit. Very easy to fit so only took a day (quite a large bathroom) and easy to maintain.
Would use them again as I hate tiling.
Estate agent pic taken from site as I can't find mine
Shower is full height clad and double width
