I've been thinking about LEDs again recently and how I can get them onto the converter to make it more interesting, at least for me anyway as my converter is semi visible at the top front of my case.
Thinking along the lines of a spindicator...
...but using some junkbox parts rather than expensive micros.
Along the same lines as my spinning LED fan mod from a couple of years ago but without the persistence and running off the fan RPM tach.
Might have a quick fiddle about with this over the weekend on my breadboard.
In other news I'm looking to etch my own PCBs. I've already drafted out the circuit ready for toner transfer and SMD resistors, if I decide to go down that route rather than through hole. I should probably make one suitable for through hole as well as I have loads of the things
 If I etch my own they will be more professional, easier to build and make them less prone to circuit mistakes as you get with veroboard. I could even make kits for folk who fancy a bit of soldering themselves.
I'm getting an old oscilloscope later in the month so I will be able to actually visualise the output of the converter properly at last rather than guessing.
