I would like to point out that I picked this one only because of low RDS(on) and logic level and was just an experiment. If I'd spent longer researching I may have found a better component for the job.
As an aside the later versions of the Phanteks PWM hub use a D1M1425 P-ch Mosfet which is also logic level and has an even lower RDS(on) of 14mΩ.
I was trying to minimise voltage drop across the transistor and have less heat. A lot of the specifications of components are beyond my comprehension having never really studied electronics design properly.
