Carlos, who I sent a build off to a while back, decided to make a few PCBs and sent me a few to try out...
So I loaded up the components on one of them to see how it looked and how it changed the build time and quality.
Overall it makes it much easier to build. It's just a matter of shoving a few leads in holes, following the polarity in a few cases and soldering the leads from around back.
I bent the 4 pin PWM connector off to the side thinking it might be nice to have it come out the side, but decided to go back to straight up for the remainder. It is intended for a panel mount Molex but I couldn't find any. I also didn't bother to fit a heatsink to the PNP.
The holes in the PCB were quite tight for the resistors and the larger 330 Ohm resistor barely fit and had to be pulled through with pliers and due to its size had to be vertically mounted.
It certainly sped up the build time, at the expense of a approx £1 per PCB vs a 10s of pence for a length of strip board which requires cutting with hacksaw and drilling of tracks to lay out the circuit. It was much easier to solder and also limits risk of solder bridges and has far less stray capacitance.
If I were to sell these I'd probably have to make a 4 pin extension cable to go with each, otherwise an extra lead would be required.
So many thanks to Carlos for sending me these all the way from sunny Spain.
