I have an idea for a web-based application. In terms of it's framework there will be an MS SQL backend (possibly MySQL to begin with) then a bunch of web forms for adding data.
E.g. you might have a contacts form + supporting table, then an Incidents form and supporting table but all related. I'm sure you lot will get the idea.
I used to code a long time a go but it was mainly scripting languages. Since this will be a fully fledged web application I'm guessing I'll be needing something object orientated like .NET or Ruby.
I figured I'll learn it myself. Looked into hiring some people in India but the reviews are terrible + too expensive hiring talent over here in the UK!
I want to keep time down but not compromise on quality. Based on those two things which platform would best suit the project? TIA
