Clock for clock the 45nm quads are a bit faster too.
Well, how about sell your B3 Q6600 and grab a 2nd hand Q9550? The chances are the Q9550 will rise in value by the time you do a full PC upgrade (may be next year?)![]()
I'm not so sure, the G0 Q6600 is a proven clocker, your going to spend more on a Q9950 and then need to hope it clocks above the Q6600 otherwise your just getting the extra L2 cache.
I think the Q6600 G0 is a free upgrade to you by the sounds of it, if your not happy you can always shift it back on since they sell easily enough on the MM, the only thing to lose is a couple of days/weeks for you to run tests, games, encoding etc to see.
shame
You have not really specified what you do with your rig but like I posted the G0 will allow for a decent overclock, i've been to 3.8Ghz from the default 2.4Ghz, thats great (I think) if you can come close to the 3.6Ghz area your on a winner, since I don't see a Q9950 going much further if at all close.
You'll know soon enough what the best action to take is.![]()
Q9550s clock well and run cool at lower volts. As a generalisation most Q6600s will do 3.4/3.5, lots will do 3.6, some will do 3.8 and very few with do 4.0+. The Q9550 has a bit of a higher starting point with nearly all doing at least 3.6 and lots doing 3.8GHz+ lots again hitting the 4.0 barrier. Of course this is going on OCUK users rather than ur average joe.
