- 21 Nov 2009
Vcore 1.25v (VID 1.2625)
CPU host frequency 400mhz
CPU clock ratio x8
Load line calibration ENABLED
DRAM Voltage 2.1v
DRAM timings 4-4-4-12
I run this on a giga EP45-UD3LR with the same OCZ plat ram.
Disable the load line cal option i need to hump Vcore up into the 1.3's to acheive a stable OC.
At the mo cpu-z/HW mon tells me Vcore is 1.28v.
Basically try the load line cal option if you havent allready unless this is something really bad and will kill my cpu within few years ? i dunno tbh im hapy with 3.2ghz now so havent messed/researched any deeper
Temps wise prime dont even hit 55degs IBT pushing around 65degs and idle around 35.
CPU clock ratio x8
DRAM Voltage 2.1v
