Q6600 water
26 Jan 2006
What I should expect rom a Q6600 with water? (spec in sig)
Does ocUK stcok the "new" ones btw? I am a bit behind with CPU's and intel in general so any info are welcome please :)
Mobo will be maximus formula I think.
Thanks
Near 4ghz probably.
I have mine at 3.8ghz for normal use but has been benched at 4ghz and thats with my dodgy water setup Ive been sorting out!
Yeah make sure you get a GO, NOT a B3. The GO as a few quid more but only have TDP of 90W and not 135w
Intel Max Temperatures
--Core 2 Duo--
E4x00 M0 - 65w TDP, 73°C max temp
E2x00 M0 - 65w TDP, 73°C max temp
E6x50 G0 - 65w TDP, 72°C max temp
E6540 G0 - 65w TDP, 72°C max temp
E6x00 L2 - 65w TDP, 61°C max temp
E4x00 L2 - 65w TDP, 61°C max temp
E21x00 L2 - 65w TDP, 61°C max temp
x6800 B2 - 75w TDP, 60°C max temp
E6x00 B2 - 65w TDP, 60°C max temp
E6x20 B2 - 65w TDP, 60°C max temp
--Core 2 Quad--
Q6X00 G0 - 95w TDP, 71°C max temp
Q6600 B3 - 105w TDP, 62°C max temp
QX6x50 G0 - 130w TDP, 65°C max temp
QX6700 B3 - 130w TDP, 65°C max temp
QX6800 B3 - 130w TDP, 55°C max temp
http://valid.x86-secret.com/show_oc.php?id=280185
Thats on water... I normally run at 3.8ghz but its stable @ 4ghz
TBH, a maximus formula is a waste on money on water cooling IMO... The main advantage over something like the P35 boards is higher Vcore settings other than that x38 is bugger all different to P35... but more than 1.7vcore is silly unless you're planning on moving onto phase...
Get something like a P5K-Premium
pfffffffffffffft.... got eat some Pi :p maximus rocks, especially the SE edition :p
Stelly
:) Max Formula are lovely boards but as monstermunch says a P5K-E or Premium will be fine for clocking up to around 4ghz for everyday use on air or water... unless you plan to run some very fast suiside superpi runs on phase cooling you wont need anything better motherboard wise
--Core 2 Duo--
--Core 2 Quad--
Where did you get this from?
DeadMan
Stelly
I didnt slate the Maximus, just said it was a waste of money unless you're planning on extreme cooling...
x38 is bugger all improvement over the P35 chipset... A good P35 Chipset will do the same FSB as the Maximus at nearly half the cost...
Air or water cooling go for a good P35 board like the Abit IP35 Pro, or the P5K-Deluxe or Premium...
C'mon stelly :p
C'mon stelly :p
You have a point, the P35 Asus Blitz Formula (as in my sig) eats X38's for breakfast :)
