- 16 Nov 2011
Multi room box has to be connected to phone line (the boxes do call backs everyday and yes they do issue out fines but it's usually after 2 warnings then fine with service cut off)
Single box does not need connection to phone.
It's no longer a requirements for them both to be plugged into the same phone line - they now use the Internet as all new Sky boxes are WiFi enabled. At least for new contracts - unsure how excising non-Internet enabled boxes are effected by the change.
Via either method they will not know the moment you unplug it. The boxes call home every so often (usually once or twice a month) and if they are not from the same phone number/IP then Sky go nuts.
Well like I said, I am happy to transfer the account, but not at the expensive of an engineer's visit and then another one later on when I take it back.
