Question on external storage issue
13 Sep 2008
Hi
I wondered if anyone had experience with something like this and might think of something else to try;
I bought one of these
http://www.overclockers.co.uk/showproduct.php?prodid=HD-052-BT
Which is an Icy Box IB-3221StU-B, just a 2 into one USB JBOD enclosure. And a new 1TB WD Caviar Green (OEM, unformatted) to go inside it.
Try as I might I cannot get the PC to see the drive in the disk manager in my computer in order to format it. Its not got the wrong name as I checked for that, its just not there in the list.
I've tried different plugs, having it as the only USB device, putting the HDDs in different trays in it, powering it up and down etc. I can hear the HD spinning up but then the little indicator light showing the HDD is there goes off and it does nothing else.
There is an entry in the manual about setting jumpers to effectively throttle it down to 1.5GB from 3 which I can do in position 5/6 on the WD according to its sticker, which I'd try but it didn't come with jumpers. So while they send me some (which is nice of them) I wonder if anyone had other ideas?
Edit: Disk manager not drive manager. Apologies.
Thanks I installed it temporarily as a third internal drive and formatted it that way (thinking perhaps it would help the enclosure 'see' it if it was formatted first) but it still doesn't work in the box.
Ah well, the trick with the jumpers didn't work, so back goes the box on RMA.
Should have stuck to a single caddy or just buying another external drive. Sigh.
