Quick question about GTS noise
28 Nov 2007
Hi this is a real quick question about vid cards on the following page...
http://www.overclockers.co.uk/productlist.php?&groupid=701&catid=56&subid=927&sortby=priceAsc
Which of these would have the quietest fan, or in general which brand is normally more quiet?
Please some one reply as I need to send away for some new parts for a new pc to play crysis and other new games (I cant even play cod 4 on current system).
Oh and another small question .. would the Quad Pro Q6600 thats guaranteed to go to 3ghz be a good cpu choice or should I go that bit extra and get something else? I have never overclocked before but it looks like its idiot proof or is this just to sell them... ?
Big thnx to anyone that replies cos that means I can order quicker and maybe get stuff for my days off work :) w00t ;)
They all have the same fan / cooler and are very quiet.
And just get the normal Q6600 (as all of them will do 3gig) and people on these forums will help you overclock it.
Spend the extra few quid and get a board thats known to be a good clocker.
They all use the exact same cooler, fan runs at 36% duty most of the time unless it gets really really hot and overclocked. Get a good P35 motherboard and unless you do a lot of video encoding or need all that CPU power get an E8xxx Duo instead.
OK ive been busy with work and am only getting round to this again today.
Which of these is better..
http://www.overclockers.co.uk/showproduct.php?prodid=CP-161-IN&groupid=701&catid=6&subcat=793
or
http://www.overclockers.co.uk/showproduct.php?prodid=CP-210-IN&groupid=701&catid=6&subcat=793
I have reason to be confused so I need my mind put to rest before I buy ;)
Current hardware ive choosen..
8800GTX -- £230
Q6600 -- £150
Abit IP35 Pro -- £120
OCZ 2GB -- £50
using current 750 Watt PSU and X-Fi
Total: £550
This hardware is said to work well together and will surely achieve the 3Ghz OC. I was thinking that maybe an SLI mobo would be better for me in the long run but I dont want to mess this set-up up and not get my overclock.. surely theres a sli motherboard that would do the job? In general should I go a bit further money wise and change something?
