Quick question about Seagate 7200.10 drives
If you're regarding the SATA-150 legacy jumpers then no, there's no reason for it to cause data errors, just make sure your chipset is capable of SATA-3Gbps (SATA-II) speed. Even if it can't, the drive should auto-negotiate.
hehe sames lol, i got a second 320 drive and read the label and looked at my original and slapped myself :p and yea i think my mobo can handle sata2
Just be aware that you won't notice any difference by removing the jumper, all that will happen is that the burst transfer rate will go up but any serious amount of disk usage will be reliant on the sustained transfer rate which isn't limited by running in SATA1 mode.
K K cheers for the info :)
one thing i noticed recently has got me confused - i have a sata-I motherboard and one of my hard drives failed a few weeks ago so i sent it back to seagate - anyway, that drive was a sataII but had no jumper on it at all - it worked fine but the burst speed was over 200mb/s. I never really thought about it until today as the new drive to replace it does have a jumper on it, which i left at sataI, and the burst speed is less than 150mb/s.
how is it possible that the burst speed of the old drive was higher than 150mb/s if the MB only supports sataI?? - i'm confused.
What mobo is it?
