Tosk said:
any 1 here tried the Coolink SWiF-801 80mm & Coolink SWiF-1201 120mm
are they quiet ?
Ya I would like to know this too please if anyone can give some feedback on the Coolink SWiF-1201.
I am torn between the Acoustifan Dustproof Quiet and the Coolink SWif-1201.
I like the 3 fan setting options the Acoustifan provides, However I also like the 2 Options on the Coolink because the lower speed in specs is 1.0dBA Lower than the Acoustifan and also It has a fan controller for a spare PCI slot.
I just dunno what the best is to go for:
5v - 25.2CFM - 10.0dBA - 675RPM
OR
7.5v - 22.2CFM - 9.0 dBA - 700RPM
I still have to look into if my MSI RDA480 Neo2 can support the Acoustifan with it being only 3 Pin (Coolink has both 3pin and 4pin) although i suppose I could use a convertor maybe?
BTW this will be for my computer I use in my front room which is on almost all the time and mainly used for making music (Hence noise being a big issue) and the CPU inside is an AMD 64 x2 4800+ which I have next to browse for a heatsink and fan also with very low noise as I don't think my stock AMD 64 3000+ fan will work on the x2 4800+ and also it is too noisey if I am forced to buy a new one.
I just hope the low noise settings will also push enough air to keep the x2 4800+ cool enough (it won't be overclocked)?
