NachT said:SilenX iXtrema Pro's have a rated dBa of only 11 !!
I don't own any, but i'm thinking of buying a few now
Havn't seen any that have been rated quiter than these, the Silent Eagles are 19 dBa.
NachT said:I don't own any, but i'm thinking of buying a few now
NachT said:Havn't seen any that have been rated quiter than these, the Silent Eagles are 19 dBa.
WJA96 said:The AC Fan 12's are rated 10-23db over their working range and they will shift a lot more air than either the Sharkoons or the SilenX's.
http://www.arctic-cooling.com/fans2.php?idx=111&data=2&disc=
Flanno said:Nice one...I was thinking of these fans too, but not easy to come by. As they use PWM do you need a 4pin header on your mobo. Not sure how many the 680i has.
tastyweat said:Noctua fans... expnsive but brilliant.
Push a lot of air and make no noise.
The 800rpm fans are inaudible! and push 35cfm. Quoted as 8dB iirc.
Their 1200rpm fans are great too - 55cfm @ 17dB
Marshall said:Im looking for a couple of really quite case fans with blue leds, which ones can you lot recommend
I've got a Tuniq Tower but not got any intention of replacing the standard fan just yet. Was just going to use the S-Flex or Noctua as intake and exhaust fans in my case. If they both push a similar, decent amount of air but the Noctua are a touch quieter, then i may as well go for them. Cheers Flanno.Flanno said:As for the vapors review, I am no expert but I had nexus fans before and the noctuas physically feel like they push a lot more air. However I have heard the Noctuas are not great on heatsinks. I just use them as case fans as they were designed.
