- 25 Nov 2002
- Somerset
Arrived at last, the long awaited .45nm Quad core
If you thought the cost a bit steep, lets just look at what you get.
1. A very big box... the box is twice as big as a normal C2D box
2. A very big Heatsink... still useless cos who used the stock HS
3. A tiny piece of silcone.
Anyone else mad enough to have brought one of these, please post your findings in here
Let me start...
My aim is to be able to run day to day at 4ghz with a nice quiet system. But to be able to crank up the setup for some killer benchmarks. Within half an hour i think i have already achieved my aims..
Currently running Prime (30 minutes in so far) Small FFT at 10x400 = 4Ghz with 1.3v true (so thats 0.5 over volts - std is 1.25). Temps are at 58c full load... This with very poor water, probably no better than standard air cos i'm water cooling the PU, Chipset and 2x GPU's in one loop.
Super-Pi 1M at 4Ghz gave me circa 11.6 score... thats a full 1 second lower than the equivilent clock on my q6600 - so this shows the effect the extra L2 Cache has on this benchmark.
Idle temps are sat at 27c - 30c
I had a quick go at a bigger clock with these results...
To keep things simple i just increased the Multi to 11 leaving everything else the same. To get into windows i had to increase the vcore to 1.4v This was still not prime stable, but i dont want to go higher just yet.
In this I ran a 3dmark2006 test and scored 21.5k beating my previous best by 1.5k
I then increased the FSB to 410 while in windows so 4.5Ghz and ran SuperPi = 10.33
So early days and i really need to sort my water cooling out first but initial impressions are FANTATIC and despite the cost, well worth the money.
Latest Screen Shots last updated 4/12/07 5:50PM
First 4ghz low voltage Prime Stable for 1 Hour
Next - Max Overclock with Sub 10sec SuperPi
Let me start...
