- 8 Mar 2006
- Telemark
From wiki
tut tut
From wiki
tut tut
Ahh yes of course, wiki is so different to asking on a forum. To be honest something like that will be correct on wiki.
Racing fluid does not absorb water.
Racing fluid doesnt absorb water! i
The wet figures are for when you have water in the system, it doesnt absorb the water but mixes with it, since the fluid has a higher boiling point than the water in the system lowers the boiling point.
AP web site said:To obtain the best performance from racing brake systems, bleed the system thoroughly, immediately prior to each event using AP Racing brake fluid from a new sealed bottle. This is particularly important in wet or humid conditions or when the brakes are excessively hot. Always use fresh fluid and replace bottle cap when not in use. Never re-use brake fluid.
and halfords brake fluids are not racing fluids lol.
yes but it doesnt absorb, if you empty brake fluid into a container from the car you will see the water floating on top of it. It mixes with the water lowering the boiling point.
Fair point.
I like to use Wikki as a start if I have no idea at all on a subject, but anything i reference to later is from separate sources. Mostly because if I hand in a report which references Wikki, I fail.
Silicone doesn't absorb moisture, but hardly anyone uses these days due to it's numerous drawbacks.
It's expensive stuff to start using in the first place, but once in, it's pretty much fit and forget beyond normal checks. It's a pain to fit as you have to renew every rubber component in the system that comes in contact with the fluid as that negates the qualities of the silicone fluid. Not many people use it because of those reasons, or if they don't do it properly and then the seals start to leak quickly they complain.Where did you get Dot 5.3 from then?
A mechanic.
OT: So we can reach a conclusion? Don't use silicone fluid (or anything else non-hygroscopic), try to avoid anything to thin, otherwise; it's your money.
