- 30 Jun 2012
i dont really have enough room to have them any other way, and there is so much pressure pussing out tthe botto of my rad... we'll see
That's a monster!
Can you give us any ideas of temperatures, problems you're having, noise level etc? This looks really interesting.
Also, what coolant are you using? From your comment it sounds like water & antifreeze, but surely that would be conductive if it leaked?
No, a Huge ******* Monster!
show us some pics of it in your case
show us some pics of your case in it
is that a car radiator?
make sure you got a really good pump to push through tht.
spot the error, copper block, thats a copper cored rad
then i went and put bloody ally reducer blocks in it
oops. will this mix corrode the copper or just the ally, if its only the ally i dont mind as its about 8mm thick
Not really, as far as the pump is concerned its taking water from a res pumping it through two blocks and back to the res, hardly a restrictive loop.
