Ok, i've just spent over 4 hours playing BF3 today on ultra settings (the longest gaming session with my Radeon 7950 so far) and have a few issues/niggles that concern me a bit:
1. The GPU temp never goes over 61C no matter what i run and how long i run it for (sounds great, but could be a sensor fault as it's starting to seem a bit unrealistic now).
2. I left the room for a while and when i came back there was a slight electrical/plastic burning smell... I can only assume it's from the graphics card as it's the only new part aside from my i5 3570K.
3. The graphics card has started making a slight electrical buzz sound under load (a kind of fuzzy sound)... Not like the typical squealing coil whine found with some graphics cards.
4. My VRM temps are still stuck at 24C all the time and the GPU still runs at an insanely high 1.25V when gaming! BF3 started to get a bit glitchy towards the end of my session (textures flickering and some even disappearing!).
5. Why does the GPU fan run at 100% for 6-7 seconds when i switch on my PC? It's loud and no other card i've owned has done this!
... Is any of this a good enough reason to RMA the card? And do i do this through OCUK or the manufacturer (HIS)? I've had the card for just over 2 weeks now.
When I built this system couple months back and after couple use I had this burning smell, even made topics about it on here but has time passed day or two it went away.
If you have a good cooler on the card temps should be low on theses cards I never go over 62C on BF3, But Heaven Bench I reach 67C.
The Start up is normal dont worry about that its a good way on getting dust of the fans.
. It still made that strange electrical buzzing/static noise and it does have a smell to it (maybe it's because it's new and hasn't been used extensively until today
... The game also stuttered frequently and the graphics started glitching! The biggest shock was the GPU's voltage which reached a massive 1.438V during gameplay
!! (i checked the max readings in GPU-Z)... I wonder if the VRM's are a bit iffy (which could explain why i can't get a proper temp reading from them).
). HIS are usually quite decent, so maybe i've just had bad luck with this one.
