Well, Fury's are EOL, you not noticed?![]()
I did not.
I did not.
How much must you guys be gaming for 50w to make a difference. My tortoise Arnold has a 100w light bulb on 10 hours a day and I don't even notice it on the bill. In other words I just want maximum performance.
Ouch. But then again, I wouldn't mind that when I am on an all day session gaming![]()
When NVidia are ahead, the AMD crew will tell us that power doesn't matter and when AMD are ahead the NVidia crew will tell you it doesn't matter.
I thought this was the start of a joke when I heard you had a tortoiseLove the name! I don't worry about the power my card uses but I also don't want a hot card either unless it is powerful.
I can't see 4GB vs 8GB cost an extra ~£100.
Or just having a single card from one SKU.
I think Tweak Town let slip there...
If RX 480 benchmarks hit before Jun 29 the NDA is protecting a 490, the $300 card
Actually, I thought we were mostly just telling D.P. that power draw and TDP are not the same thing.
Power is important in laptops and tablets, it's irrelevant (to the degree it differs with these cards) in desktop systems. That was my position a year ago, it's my position today. You can check old posts.
See,that your problem. You are telling me peer draw and TDP are different, which it know and I don't care about.
I'm only discussing power draw, only using AMD's figures from AMD's website and financial reports. You are the only one that is ranting on and on about the differences between TDP and power draw.
Okay. Let's do this again.Could you link me to the official "power draw" for an AMD card. Any current card of theirs will do, but 390 might be a good starting point as you keep using that one in your examples. Link and official power draw required.
Personally I think AMD have closed the gap somewhat, and moreover the difference between 1010w and 140w is meaningless for this part.
Not sure what to make of this thread:
https://www.reddit.com/r/Amd/commen...une_29th_nda_is_for_the_480x490_and/?sort=old
If you look down the page,a chap who is an editor of an Italian techsite says the full Polaris 10 chip has 3072 shaders??
I did previously, you complete ignored the links to AMD's own product specification and you went off on a pointless rant about the differences between TDP and power draw which was irrelevant to the discussion.
Look, I'm not having a go at AMD's power draw or efficiency at all, I don't care. I'm just pointing out a few simple facts. For starters, at computex AMD said < 150w. They didn't say < 100 w. So why are some people trying to claim the latter when it goes against what AMD have announced.
Personally I think AMD have closed the gap somewhat, and moreover the difference between 1010w [edit 110w] and 140w is meaningless for this part.
3072 shaders would be 48CUs, that's be hard to fit in the space quoted for Polaris 10. Not impossible, but on the upper end of 'unlikely'.
Unless AMD has made some more changes to the shaders to make them more compact?? We kind of saw the same going from the RV670 to the RV770 on the same node. Die size went up from 192MM2 to 260MM2 but the shader count went up from 320 shaders to 800 shaders.
How so?Quite frankly if the RX 480 8GB comes in at ~£230 then it's pure failure unless it is well above 390X performance.
