Caporegime
- 8 Jul 2003
- In a house
this
970 is soooo 2014
but its the same performance.
this
970 is soooo 2014
It's actually worse on the 960 since it spikes much higher but no one complained or had their mb destroyed yet.
People going on about the pcie spec, cards in the past have also exceeded it, 6990 in bios 2 mode and 295x2 being 2 of them.
Even the GTX 960 did it, it was even worse at it than the 480 was. There's a screenshot of the review for it and 480 as comparison.
Its nothing new really but plenty of drama surrounding it =/
Anandtech included this about pcie spec in their 6990 review.
http://www.anandtech.com/show/4209/amds-radeon-hd-6990-the-new-single-card-king/5
How right you are sir!
Looking at some of the crossfire results that are starting to come through suggests that you should not just buy one, you should buy two.
In all honesty I am a little dissapointed that the RX480 is not the 390X/980 equivalent that we hoped it would be. However, AMD have never quoted that it was going to be. That was all from hype and hope on this very forum.
However, this morning after trawling You Tube I have seen what can only be called pretty favorable crossfire game benches across almost all games (6 mainstream AAA titles not withstanding, which do also have some SLI issues too or no support at all).
Has anyone else seen any RX480 crossfire benches and if so, what do you think?
Really, form the crossfire benchmarks have seen it is pretty similar to a 1070 when crossfire works but you are paying more, producing far more heat, and have all the issues that crossfire brings like stutter or simply not compatible with games.
It depends a bit on how you exceed the spec - we've had cards in the past that massively exceed the thermal and electrical guidelines but don't draw massively from the PCI-e connection itself - while in this case it looks like the card can draw quite a bit from the PCI-e connection in certain overclocked scenarios.
Fair play to OcUK/Gibbo for securing exclusivity of the 4GB in the UK (explains why no other retailers have any stock)
There is no 4GB exclusivity it seems, just 4GB disabled by vBIOS on full 8GB capacity cards and unlockable by simply running an .exe file. Happy days for those who bought on launch day.
http://www.legitreviews.com/amd-radeon-rx-480-4gb-video-cards-8gb-memory_183548
http://www.legitreviews.com/amd-radeon-rx-480-4gb-versus-radeon-rx-480-8gb_183576
Any chance of posting a link? Cheers.AMD have already detailed this on Reddit.
