New leaked photo of Vega 10! It's called the RX 590 X, and is a quad GPU. Looks like the scalability of Navi has been pushed forward.
Specs like that would make a few AMD fans hard.
I think they needed to get some proper software out to the public so they can test things on a wider scale and also get a sense of where to put their priorities. It is still lacking plenty of things that many of us expect from games nowadays, and it will probably take a while for it to grow into a really appealing prospect. If it ever does, obviously, no guarantee of it or anything.They are the kind of features you expect to be missing in an alpha build, maybe early betas not in the release version of the software.
Very strange thing to say considering the intent behind UWP and the unification of their console and PC gaming efforts. I dont know how successful it'll be in the end, but this is what I've been hoping MS would do for a while now and I'm quite excited to see what comes of it.I dunno its like there is no one left at MS any more with real experience or broadness of vision.
Because if you do something badly once, you are forever doomed to do it badly in the future?Games for Windows Live 2.
Still no benchmarks for this card?
A 2560 shader part@ 1400mhz would still only be 7.1Tflops. Still not even close to a FuryX.
It would run far closer to its theoretical performance though, so it would be far closer to the fury x than you expect. If not matching or exceeding it.
Consider the preliminary info on the rx480 showing it having greater than 390x performance but lower theoretical performance.
why I keep thinking and pointing out - 480 will most likely start with 390X/980 performance and end up with driver improvements about nano speed..I'm thinking fury x speed is a little high hehe
We are talking about hypothetical 480x speeds.
Going back to the reply I got. Iv been wondering is it possible to achieve the same gaming performance with less tflops on the same vendor?
In the original quote he was talking about a theoretical 480X with 40CU's at 1.4ghz. which is what the Fury-x part is in reference to.
the 480 bit underneath is just me explaining the increased per shader performance giving the part better performance than the 390x, even though its theoretical performance is lower than the 390x.
hence a larger part with higher clocks and more shaders should match the fury x or exceed it, even if its theoretical performance is lower.
