- 31 Jan 2011
- Hampshire
Hello all
My PC has seemed to have developed a random fault. It seems to totally loose power for about 5 seconds. Its as if the Mains cable has been pulled. Everything goes off and i get a "pop" from the speakers. Then 3-5 seconds later it powers back up again and works fine. Its only started doing it (no hardware changes at all) am i right in pointing the finger at the PSU ? The psu is a CORSAIR HX 850W Purchased in May 2011 (7 year warranty to) everything else is relatively new CPU MOBO / less than 6 months, Graphics card 3 months. i have checked all connections with nothing being loose.
Sometimes it can go 3-4 hours without a problem then others just an hour. I think its load related as it only seems to do it whilst gaming (the most PSU load too) however i think the PSU is more than gutsy enough for my hardware (see sig)
Whats your thoughts ?
came from a portsmouth based company that i have had nothig but problems with returning stuff. Still will give it a whirl. Not sure i can go without a psu for this long tho
