I'm going to get straight to the point
We just moved house recently. The move went well etc, etc. I set up my rig and looked inside, it was a bit dirty so in the new frame of mind after the move i went sinde and cleaned it of the little dust what was there. I then proceed to turn my pc on after setting it up. I get a message like to format, so i was like god i hit something. It then says go to bios or reset, i check bios everything is as it should. I reboot, same message comes up so i reset, which i then think wiped the bios to standard. Anyway, so now this i try format my pc, i had 3 hard drives two dualled into 1 and 1 for my os. I try formatting my os drive to no avail, it was showing up as not meeting the criteria for a format. So after much messing about i remove my two storage hdd's, then retry a format. It works, but when i plug them in and restart it won't let me into windows unless they aren't plugged in. Once windows is up i can plug them in and they show up but they don't show up as having any space. They're just there with no options or any space on them.
Any help would be REALLY appreciated, regards, R3dge
My rig is as follows:
Intel Core i7 940
EVGA GeForce GTX 295
Asus Rampage II Extreme Intel X58
Corsair TX 750W
Asus Xonar DX 7.1 PCI-Express Sound Card
x 2 - Samsung SpinPoint F1 500GB
Samsung SpinPoint S 80GB
G.Skill 6GB DDR3
.We just moved house recently. The move went well etc, etc. I set up my rig and looked inside, it was a bit dirty so in the new frame of mind after the move i went sinde and cleaned it of the little dust what was there. I then proceed to turn my pc on after setting it up. I get a message like to format, so i was like god i hit something. It then says go to bios or reset, i check bios everything is as it should. I reboot, same message comes up so i reset, which i then think wiped the bios to standard. Anyway, so now this i try format my pc, i had 3 hard drives two dualled into 1 and 1 for my os. I try formatting my os drive to no avail, it was showing up as not meeting the criteria for a format. So after much messing about i remove my two storage hdd's, then retry a format. It works, but when i plug them in and restart it won't let me into windows unless they aren't plugged in. Once windows is up i can plug them in and they show up but they don't show up as having any space. They're just there with no options or any space on them.
Intel Core i7 940
Corsair TX 750W
G.Skill 6GB DDR3
