Raptors or not
rpstewart said:
Do you have any links to back that up? I can only find benchmarks for the current 250Gb drives and the results are nothing special really.
likely to be on here..
http://www.storagereview.com/
Scoobie Dave said:
Have you had any trouble with your Raptors running RAID0?
no problems at all, have used them on two different motherboards (upgrade)
i do keep copies of all my data on my raid3 setup though
HeX said:
The 7200.10's arn't that far behind the Raptors.
They are actually faster at burst and conecutive reads due to the massive platter sizes and the vertical recording.
The Raptors are only really faster at seektime and random reads due to the faster motor.
If you look here:
http://www.anandtech.com/printarticle.aspx?i=2760
Scroll down to page 10 and get past all the meaningless 'virtual' performance benchmarks, and look at actual Game loading times, WinRAR, etc. etc. tests then RAID 7200.10's is very close (and actually beats in some) Raptor 150's in every test.
Just a single 150gb raptor is beating even two the seagate 7200.10 in raid in almost all them game install and game level load tests...
It's on OCUK's site, one of the Samsung SATA drives. I can't remember which one though but it does definately say it. And i can vouch for it, they are fast.
bledd. said:
the manufacturer is called 'silent star' or 'silentstar', its a dual hard drive watercooling block, fits in 2x cd drive bays
its really heavy though, a few kg's before the raptors are in it, but it has noise insulation around the inside of it too :)
Its an Alphacool (manufacturer) Silentstar (model) ;)
Alex_6n2 said:
So 2x 36GB raptors with 16MB buffers are slower than 2x 150GB Raptors with 16MB buffers?
How so?
My guess is higher platter densitity. For a defragmented 2GB file it takes up less physical circumference on the disc, therefore the heads move less.
Oh.
I saw people talking about the older ones with 8MB buffers being slower. I'm guessing these newer 16Meg ones aren't as far behind?
For anyone running 2x74gb raptors (16mb) - how loud are they?
Considering setting that configuration up - but was just wondering how noisy it is.
Get Perpendicular!
But otherwise Raptors are just 'cool'.
Dont mean to hijack the thread but Im about to format my 8mb cache 36mb raptor (the old Sata ones that first came out ~5 years ago) and also got one of those 7200.10's and now Im just wondering which hard drive you guys recommended me to install windows xp on?
I was thinking maybe install it on the raptor and leave the other for my personal files and program files/games? Or should I definately put windows xp on the new 7200.10 drive and put something else on the raptor like a game I frequently play?
Cheers
I have been using a Seagate 7200.10 250gb for a few weeks as my os drive getting 75 mbs transfer, 208 burst and 13.3 seek.
This morning I installed a 74GB Raptor bought new from OC as I wanted a nipper system and installed my OS on it and the Seagate for storage. The Raptor returning 85mbs transfer, 136 burst and seek 8.0.
Can't see what the fuss is about, in normal use and bootup I see no difference.
Both are in SilentMaxx enclosures and the WD is louder on seek but not intrusive. WD also running about 4-5 degrees cooler than the Seagate.
Not the news i wanted to hear.
I just bought a 36GB raptor and its arrived this morning, about to install windows on it. If it turns out to be crap im selling it on and saving for a raptor x or another gig of ram.
Good choice?
Good choice?
If it's the new model with 16Mb cache, it should do nicely for your windows drive and you won't be disappointed!
I used the 8Mb model for my system drive for a year or so, it worked a treat and was very fast and reliable...
