- 7 Mar 2013
- Caistor
The simplest and neatest loop for me is as follows (assuming I can make the bends).
Does anyone have an aversion to this before I make a start?
Draining point?
Draining point?
I'd have the flow of liquid going the other way round, but that's just my preference.
Draining point?
btw is that psu meant to be orientated that way?
Have you drop a silver coil into your water?
That will stop algal growth.
I used EK-Ekoolant which says it has an Anti-Algae additive. Is this not enough?
Ah, my bad. I probably should have used the word coolant instead of water.
Thanks deFiniLoGy
The Asus Rampage III Extreme...
No need to disturb this waterblock either. Or the good old fashioned 6 core goodness underneath!
