Jeese! what PSU you running that setup on?i7 @ 4ghz @ 1.4v
BFG GTX 280 OC 2x Sli @ Stock OC
Full load = 861w
Full load = 861w
i7 @ 4ghz @ 1.4v
Full load = 861w
The cpu is way under powered for quad sli isnt it? 680i mobo and four 8800GS with a E2200. It's even at stock!!
Yup thats everything off the one socket.Is that with the monitor and everything or?
Below is a table showing the Watt draw for the 3 PSU's I own running the system below.
System Specs
Asus Rampage Formula X48 Mobo
Intel E8500 [email protected] (Idle @3GHz with speedstep)
4x2GB DDR2 PC5300 @ 500MHz
HD4850@700/1155
3x 7200rpm HDD's
DVD, Sound Card, TV Card, 4x120mm fans.
I found that running Furmark and Prime95 together produced higher power draw than any other combined GPU/CPU software stress testing or gaming. Running Furmark and Prime individually shows how much the GPU and CPU consume each when loaded.
I also found that my cheap £70 "Hi-Power" branded modular PSU performed more efficiently than branded (and highly acclaimed) PSU's costing significantly more. All PSU's had rock solid rails and run very quietly all of the time.
*All measurement taken from the plug socket and averaged over a 10min period.
