- 12 Feb 2014
- Somewhere Only We Know
Yes they are in the 2nd and 4th from CPU, it was one of the things i double checked, I had the ryzen computer working until i changed motherboards(unfortunately i threw it out) which was why i was certain it was the motherboard.
i have downloaded memtest86 do i use rufus to get it on the flash drive or do i just extract it and put it straight onto the flash drive?
you can download a USB stick version or a CD version, if you downloaded the USB version, just plug in your flash drive, double click the exe file and follow the instructions, it will do the rest for you.
