- 9 Jul 2007
- Northern Ireland
Hi Guys,
I’m pretty new to this and having a few problems and I’m sure you experts will be able to put me straight.
I’m using an Asrock ConRoe1333-DVI/H Motherboard and bought an E6750 2.66Ghz Core 2 Duo, but problem is I can only get it clocked to 2.88Ghz and by reading around I can see guys getting 3.5Ghz with ease, so I was just wondering if its maybe me Mobo that’s the problem. I was using a 2.8 GHz Dual Core with the same board before I bought the E6750 and had it clocked without any problems to 3.2 GHz and up to 3.8 GHz before it become unstable.
So here a few things I wrote down that might help.
Bios settings:
Overclock Mode [CPU, PCIE ASync]
CPU Frequency (MHz) [364]
PCIE Frequency (MHz) [120]
VCCM Voltage Auto
Clocked to 2.87GHz.
I’m using 1.5 Gig Memory DDR 2 667
500W PSU
Arctic Freezer 7 Pro Heat Pipe Cooler 775
2 Sata HDD, 80gig and 160gig
256 NVIDIA PCI-E Graphics card
If you need any other info I’ll be more than happy to give it to you.
Here is a screen shot as well, if I go 1 notch higher either way it just comes up on the screen after bios to “load bootable media or removable disk and hit any key to try again”
Bios settings:
VCCM Voltage Auto
Clocked to 2.87GHz.
500W PSU
It doesn't overclock well
