Really need some help
so none of the cards work? one by one or both together?
you tried the other pcie slots?
the board should auto detect when a gpu is installed though i have seen the switch or components that detects them fail and an rma of the board is needed
you could try the modded beta bios with latest drivers,it might help idk
GA-Z77X-UP7 BIOS F7a mod4
Modified with :
Intel Legacy RAID for SATA 11.6.0.1702 to 13.1.0.2030
Intel UEFI RAID SataDriver 11.6.0.1702 to 13.1.0.2030
Marvell 88SE91xx Adapter 1.0.0.0027 to 1.0.1.0025
Intel PCI Accelerated SVGA BIOS 2137 to 2170
Intel Sandy GOPdriver 2.0.1023 to 2.0.1024
Intel Ivy GOPdriver 3.0.1023 to 3.0.1027
Atheros PCIE Ethernet Controller 2.1.1.1 to 2.1.1.5
Intel Boot Agent PXE 1.3.81 to 1.5.48
Intel GigabitLan X64 5.1.00 to 6.0.24
CPU Microcode Pack (Sandy 728 & Ivy 919)
ME firmware 8.1.30.1350 to 8.1.51.1471
Modified splash logo 2
http://www.mediafire.com/download/yognpyeh37y7d31/z77xup7_mod4_f7a.zip
i cant think whatelse you can try
you need to install graphic card/plug the display cable from monitor into it and try booting
ive no idea whats up if the NVidia cards work fine
can only put it down to two faulty amd cards or bios incompatibility with either the cards or the motherboard
very strange though
