Hi all,
My rear brake pressure switch is leaking. The issue is I have no idea how I am supposed to replace this.
It is leaking from where those wires with the red spade connectors connect to. Now I have been told that I need one of these, just need to make sure I get the correct size: https://www.demon-tweeks.co.uk/Prod...V8DLTCh2LUAIDEAQYAyABEgLOAvD_BwE&gclsrc=aw.ds, however how does this fit?
I was pressuming that the black bit the wires connected to inside that metal housing would be the banjo bolt and would unscrew, but I have tried that and am having no luck removing it.
Does anyone have any idea what I need to do here? I have done so much work to this bike and am so close to getting it back on the road and this stupid little bit is frustrating the life out of me.
Thanks in advance.
Thanks in advance.
