Rebox case
the pics are better than usual, just try not to get your shadow in the pic :p I think that'd look awesome with some black allen head screws :)
Yeahhh I know. It was really a quick thing at 1am xD
I don't know what the screws are so I could spray them but I don't know if it will work >_>
Just to say - great! I got one of these, and am impressed. Well made little case. I intend to laser cut a new front panel in silver, lets see how it turns out! No idea if everything fits of course . . . . :D
The screws are stainless steel ;) You could paint them with with pretty much any spray paint . Just be careful not to fill the allen socket . When you refit them the paint might chip out of the socket but you can touch them up by spraying the paint into a small cup and then using a small brush :)
I can't wait to see too :) I'm working with some mirrored acrylic for a job and I did wonder what a completely mirrored case would look like ;)
@bugeyewrx you still making & selling these?
@PhillyDee what kit did you buy to put inside of one of these?
I am using a cheap mITX board with an E2160 or somesuch beast. It was only to run my laser cutter from :D. I never got around to shifting the cases, might give it a go in a couple of days!
