next question, what sort of games you looking to play..?
Well, £80 budget pretty much already limited your choices. Either stretch around £5-£7 to get a 5750 512MB, or a 2nd hand 4870 1GB at £65-£70.
That's way to much. Any other suggestions?For gaming, it's pointless buying anything less than this:
Gigabyte GeForce GTX 460 OC 1024MB @ £176.24 inc VAT
I suggest you save up.
4870 is a good shout, they are still reasonably good cards. seen a 4890 in some store in highstreet, used, the other day for £79.99![]()
I suggest this because if you go with a cheaper card you either won't get the performance you want -at all-, or you'll just have to replace it earlier as new titles come out. So in the long run, this is the best bang-for-buck card on the market today.
dunno if that will be an immediate problem though, since when i bought 8800GTS people were 'warning' of incoming DX10 games that would require that sort of card, years later and they're still perfectly capable of running on DX9 without too much sacrifice. usually offering better performance may i add, in the obvious case of crysis for example.![]()
I guess I could save up to buy the one you are suggesting and maybe along the way newer but cheaper ones could possibly come out.
Graphics cards are unlikely to get cheaper, don't plan for that scenario.
god don't get a 8800GTS, they are getting a bit long in the tooth shall we say.![]()
