What about a small metal loop through the sony?
That's what I did then fastened my paracord strap through it.
not sure a triangular snap ring or any other kind will fit the RX100
if it doesn't, would this be ok ?
http://www.ebay.co.uk/itm/1-4-Screw...310446?hash=item4868c3d76e:g:H0AAAOSwBadTqtvl
wont I be using that to connect to the SLR ?
got a pic ethan ?![]()
Another option - buy some of these and use a "normal" neck / wrist strap ?
http://www.amazon.co.uk/TECH-130111...53234442&sr=8-1&keywords=optech+mini+qd+loops
The 1mm chord should fit through the tiny Sony fixing points![]()
I don't know how or why it doesn't show when I load the image link using the insert image image button? Anyway, I just used one small but sturdy loop/clip through the opening on the RX100 and then attached a Paracord wrist strap to the loop.
just been trying to put a very small metal split ring through one of the hooks for the strap and I broke the bit of the camera in doing so![]()
