Recomend me a strap for 2 cameras
Looks a tidy and comfortable case. Less bulky than the one I use. Glad you managed to sort something out.
the case, is perfect for it, its a Lowepro Apex 20 AW
doesn't move around at all, snug fit :)
well, I'm getting there with it, shame ive broken the loop hole on the side I actually need
so I cant use a hand strap at all !
so ive locked 2 PD locks onto it , instead of just the one in the picture, and that works ok, its light camera so have it around my neck and the strap doesn't get in the way of the screen which is good, bit awkward, but its better than nothing
Bit of a bump !
I ordered some 5mm split rings from eBay and they came today:
Threaded them through
Then looped the PD toggle
One each side
And voila !
