Red Silence...
Yeah...cable management could be better...depending on the size of your mobo you essentially have one part to feed it all through.
I probably could have done a much better job of it however not something you're going to see. Would love a Modular PSU which would help massively.
cable management aint brilliant on ITX boards although i've found that shifting the power cables to the same slot as the usb 3 cable has helped and i plan to run the down the front of the case and zip tie them into place.The actual usb i'm gonna have to suspend from the roof and drop it in vertically becasue of the placement of the front usb 3 header on my MB
Temps wise my card was running at the rated 94-95C for an R9 290 and the CPU when overclocked is around 70C load @4.4Ghz w/1.3V on my H80i.
I now have a accelero hybrid fitted to my R9 and your talking idling @ 30-35C and load is 70C.
Sorry if it came across that i was ****ging off your cable management, i meant in this case in general
Browsing google and seeing other builds, its seems not a problem but most people struggle to get the cable management, bang on!
Absolutely love this. Was looking at the DS cases for my missus's build but she was set on the White/black combo even though I originally thought she would have liked red. After seeing these pictures she's absolutely in love with the red one...
Awesome job mate!
