- 4 Jun 2021
- Yorkshire
VersionMonkey,
I can demonstrate these things to anyone standing in same room.
If you listen to the Audio Quest pod cast he explains that even a PSU can't remove all interference entering from the mains. He then goes to say how interference eventually reaches something that's analogue that I suspect what's happening.
It would be great if you could identify where in the 31 minute podcast he makes reference to the ATX PSU spec and the level of ripple permitted from a conformant power supply. Or where he shows the ripple on the output of a PC power supply on an oscilloscope both before and after the application of mains filtering equipment.
Because that would be a really easy way of showing that mains filtering makes a difference to the output of an ATX PSU.
It would also be useful if you could identify where in the podcast he explains how that interferance can possibly overlay the CPU-RAM-PCIe-GPU-vRAM processing that then goes on before the entirely digital signal is output over your DVI cables.
The only nonsense thing is people who have never tried, arguing with someone who has tried.
The problem is the lack of any plausible mechanism whereby filtering the mains to your computer could affect the output on the monitor. I don't try homeopathy either, as its proponents are unable to provide reliable evidence for its effectiveness beyond subjective anecdote.
And the reason the thread got bumped, is Est claimed a twisted pair cable could not remove interference that was already in the mains supply. I contacted Russ Andrews about this, and they confirm that it can. It's my reply to Est that bumped the thread again.
I'm not sure that an entirely unsupported assertion made by somebody selling expensive cables that contradicts the well understood physics behind the effects of twisting cables that are carrying a differential signal is a useful contribution.
To be honest if your mains quality is that bad that you need to filter it, and you are using your PC for work as you say, I don't understand why you aren't using an online UPS to power the whole desktop.
