It's a 1999 Mitsubishi Carisma 1.8 GDI
The first problem is the remote no longer works, i tried changing the batter (battery was out for less than 2 secs), central locking still works and *** red light flashes on the remote, could it of lost the code somehow and how do you set the code?
On fords don't you turn the ignition on 8 times fast then press one of the remote buttons?
Is there a similar thing on Mitsubishi, or any ideas why it suddenly stopped working.
2nd eventually started to install the new sound system, got the head unit in, but having difficultly on what the sub box should be. I've asked on digital-car but Still no real awnsers, what size should the box be here's the info:
Phase Evolution SX10
Woofer : Sx10
Fs Hz : 35
Qes : 0.36
Qms : 3.6
Qts : 0.33
VAS Liter : 35
Xmax mm : 16
RDC Ohm : 3.5
SPL dB : 91
Enclosure Sealed Liter : 15
Enclosure Reflex Liter : 30
Enclosure Port Ø mm : 80
Enclosure Port l. mm : 200
Enclosure Free Air Liter:
Also the head unit is a pioneer and has a lovely white light to the buttons, the clock in the dash has no back light, and so cannot be seen at night
, is it possible to install 2 bright white led's behind the lcd clock would that work? one either side on the screen?
I have the Pioneer DEHP77MP headunit is there a hands free phone kit, one where you wire in the microphone to the car?
Can this head unit even do that?
Also anyone now where in the bulkhead are some holes to throw some power cables through to the cabin.
Thanks in advance
Woofer : Sx10
Fs Hz : 35
Qes : 0.36
Qms : 3.6
Qts : 0.33
VAS Liter : 35
Xmax mm : 16
RDC Ohm : 3.5
SPL dB : 91
, is it possible to install 2 bright white led's behind the lcd clock would that work? one either side on the screen?I have the Pioneer DEHP77MP headunit is there a hands free phone kit, one where you wire in the microphone to the car?
Thanks in advance
