20 Apr 2015 at 20:27 #21 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 wazza300 said: remember to wear your earplugs (like a good little boy) when you remove the baffles Click to expand... Pardon?
20 Apr 2015 at 20:31 #22 wazza300 wazza300 Caporegime Joined 11 Jul 2009 Posts 27,040 Location BenefitStreetBirmingham just a dig at the hard nose bikers who are wimpish and use earplugs you should leave em out the baffles if they aren't too loud,helps you get noticed more by crazy car/taxi drivers and lemming pedestrians they can be horrible on long journeys though,mine drove me nutts when I went down wales
20 Apr 2015 at 20:34 #23 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 Was joking I'm half deaf after a long ride already anyway. I guess I should wear some, but where's the fun in that
20 Apr 2015 at 22:52 #24 cyclops12 cyclops12 Associate Joined 23 Aug 2004 Posts 1,764 Unless you've put on a full exhaust system on you won't need a re - map baffles in or out. Even though putting after market cans on any bike might make it pop more on the over run it's not the cans or baffles doing it, it's the pair valve! If you don't want the pop and bang it's a very easy mod to do, just remove the pair valve Last edited: 21 Apr 2015
24 Apr 2015 at 21:55 #25 Craig321 Craig321 Soldato OP Joined 2 May 2004 Posts 19,950 The more popping and banging the better Think I'm going to run it in as recommended by Triumph, then take the baffles out and see how I go. Thanks for all the help
