Does anyone know a way to remove the dye stains from a cpu block??
As you can see from the photo my EK cpu block as become dyed from their coolant, is there any way I can clean this? I thought possibly alcohol cleaning solution. Though I'm not sure if this would damage the plexi or the nickle
