Removing null values from mysql output
Another thing that might work simply as well, is to replace all instances of "<li>NULL</li>" in the HTML itself using your original query, thus leaving the good data in tact.
What do you mean?
I can change the mysql query itself to delete NULL vales before php touches it?
In the following code:
PHP:
$html = <<<EOF
            <div class "{$class}">{$content}</div>
EOF;
There should be no whitespace after <<<EOF or before EOF;
The code within will appear greyed out in most editors.
I still can't get it working, I'll take a look tomorrow with fresh eyes. Thanks everyone for getting this working...
visibleman, after some reading it appears the ? !empty :
Is a fancy way of doing an if statement.
If a value is not emtpy then execute the bit after ? else its false (colon) and output "" which outputs no html markup, therefore it doesn't show anything on my html page.
Is that it in very basic terms?
It's called a ternary operator or ternary if statement; essentially a shortened if statement -
( *condition* ) ? *condition true* : *condition false*
And yup, it'll work as you suggested and won't output that particular line/HTML if the table column field is empty (NULL).
However, is there a particular reason why you're using heredoc syntax for strings rather than the standard quotation in your examples?
No, no reason, it's just how I learnt to do it from googling. I have bought a couple of php books and am slowly going to go through them, IF I can understand variables, strings, operators, functions & classes I think that will cover. I know a lot more now than I did in 2010, but I haven't followed a structure of learning as I am trying to get my first project completed.
I have found a nice beginner guide at http://www.tuxradar.com/practicalphp
