Hi all,
Similar to other thread thought I could document below and give some pics.
Its going to be a tiled floor and painted walls.
Studding out waste pipe wall
thinking of studding out the wall to hide waste pipework - means entire wall will be flat rather than a small boxing for waste pipework at low level.
I know a plasterer already and would be getting him to do the back wall by the window regardless, so once i get the wall boxed in I suspect it will cost very little (maybe £100) which I think will be worth it.
The current dot and dab is approx 25mm deep.
I would stud out 38mm (to capture the 32mm wastepipe) then 12.5mm plasterboard on top, so losing about 20mm on the wall side.
Any issue with a 32mm waste rather than 40mm?
Floor tiling
I was going peel off all the tiles
Fill and deep holes/punctures from tile removal (it's a concrete sub floor)
Liquid sika damp proof membrane (effectively paints the floor) - I don't believe any primer is required after this for Levelling?
Self Levelling compound (any recommended?)
Tiling - anyone recommend any of the "Levelling clips"?
Pictures
This is before but id already removed the pub tier horrible toilet seat
As you can see the door has been moved, I also got rid of the pullcord and instead the light is triggered by a microwave switch (similar to PIR)
This length of waste pipe boxed protrudes approx 110mm into the room (unnecessarily as its only a 40mm waste?)
![gzwJDUx.jpeg gzwJDUx.jpeg](https://forums.overclockers.co.uk/data/attachments/450/450810-54240b8c067022b4625daaf6e9dbccb5.jpg)
Floor tiling
Pictures
![rPB1AN2.jpeg rPB1AN2.jpeg](https://forums.overclockers.co.uk/data/attachments/450/450806-2f0c0f7cb688d31ebbf06d73b874ae38.jpg)
![NCLXOC4.jpeg NCLXOC4.jpeg](https://forums.overclockers.co.uk/data/attachments/450/450807-d65fbbad78b380f6bf3ced3a5093f573.jpg)
![YKZTkqY.jpeg YKZTkqY.jpeg](https://forums.overclockers.co.uk/data/attachments/450/450808-866f43076128bcbf6bde116cd23dc96d.jpg)
![hTJZLRM.jpeg hTJZLRM.jpeg](https://forums.overclockers.co.uk/data/attachments/450/450809-cc5bdbb91cc1fbffe9db9e2182f66997.jpg)
