- 17 May 2004
Think I may have to get one of these Alphacool NexXxoS nVidia 6800/7800 Graphics Card Cooler (WC-006-AC)
Tubing size is usually listed appropriate to how the fitting/tubing interface works.flipside said:Pretty sure the confusion all started when someone told me i needed 8mm to 10mm reducers. ID or OD? FFS this is crazy theres so many different types of tubing and all the stuff I have brought hasn't worked or is not gonna work & all i'm left with is bits and pieces all over my room, a hole in my pocket and a ******* headache!!
MoNkEyMiKeY said:Ive just ordered the 5.25 bay radiator. Im gonna get a Coolermaster atc 201 case and the other radiator won't fit any where I dont think. Its got a black front on the radiator though. So me thinks some painting is in order, if not if its alloy I'll be making it into brushed alloy
MoNkEyMiKeY said:Well I mean in my case I have one HDD. I would never have 5 HDD's anyhow I have 2 opticals too which I prefer at the top. If I can fit that and my old rad in then I will. The bigwater kit keeps a A64 3700 at about 35oC so its not all that bad.
