There is a wired smoke alarm in my flat which was built in 2012. The smoke alarm is a BRK670MBX, with a replacement date of July 2020. It consists of a base which is screwed into my ceiling, and the unit itself, which twists-locks into the base. https://www.safelincs.co.uk/brk670mbx-replacement-smoke-alarm/
As it needed its backup battery replacing this morning, I took the unit off, and only just noticed the replacement date. Searching online, this model has been discontinued as the manufacturer has pulled out of Europe. https://www.safelincs.co.uk/replacing-brk-600-and-700-series-smoke-alarms/
I have three options:
1. Buy a BRK670MBX replacement on Ebay where they are available, with estimated replacement date of 2026-2028. Cost £75-£100, which is at a premium compared to a generic new smoke alarm £25-50.
2. Replace the smoke alarm with a wired one + labout cost of electrician, which looks like it could cost me upwards of £200 total!! Seems excessive!
3. Replace the smoke alarm with a battery one for under £50. I would have to unscrew the existing alarm unit + base from the ceiling. Maybe I could fit the new alarm to the celing using screws or just some 3m pads literally over the hole for the cables?
My one concern is whether the smoke alarms are interlinked between flats, in which case, option 3 is a non-starter. So, I am tempted to go for option 1 for now.
Any electricians on here, or someone "in the know" could give me some advice please?
