thank you for your web note, yes this would void the warrenty
http://www.overclockers.co.uk/terms.php
The way graphics coolers are built these days there's also an element of risking physical damage, if your card is overheating the best thing you can do is RMA it.
If your card is running too hot because you flashed it to 6970 well that's your own fault, it might be that your GPU core has high electrical leakage which is why AMD made it into a 6950 in the first place in which case better thermal paste is unlikely to make much difference.
And when your GPU cooler is too loud it's your fault - you shouldn't pick up card with a loud cooler. But wait a minute - what if you wanted a really high-end GPU with as much horse-power as possible ? Well then again - your fault because you shouldn't want such high-end card. 250W+ TDP monsters and quiet on stock cooler simply don't go together - you should know better. But if you insist then you could probably try some aftermarket cooler however then you will logically lose warranty. It's logical, because why would manufacturers want you to change their perfect stock cooler designs ? Definitely no point in that - since they are so perfect and the TIM is also applied so perfectly that there is no chance you could ever EVER need anything better. So you can change the stock cooler for an inferior aftermarket but they'll punish you with warranty void. That's again your fault - because why the hack do you need to change stock coolers when everything about them is so perfect ?The way graphics coolers are built these days there's also an element of risking physical damage, if your card is overheating the best thing you can do is RMA it.
If your card is running too hot because you flashed it to 6970 well that's your own fault...
What else could it be ?I'm going to assume the above post is simply sarcasm..
As you might have already deduced - my complaint here is not ONLY that you can not modify the cooler without warranty void BUT MAINLY that the stock coolers usually suck pretty much WHILE AT THE SAME TIME you void the warranty if you replace them, SO BASICALLY that card manufacturers simply don't offer any reasonable alternatives for people who want quiet on air without warranty void - and I mean really quiet, not quiet as if some reviewers will subjectively write "GTX 580 cooler has undergone some serious changes from 4xx series and the noise didn't bother us at all most of the time" etc.ps when are people going to get it into their heads, you buy a product, if you modify it in any way you have to expect to void the warranty, this includes disassembly, changing the bios and yes even overclocking. now of course somethings are much more difficult to detect than others such as overclocking.
Evga only allow that in the us![]()
Well, is he official EVGA representative or just mod ? It doesn't sound too convincing to me. I mean if you bought it in some EU shop and then RMAed it in the same shop, wouldn't they object despite the EVGA policy ? I think they would. I have some conflicting information on this - I've also read someone else writing that EVGA's RMA policy does not apply to Netherlands (or maybe it was some different EU country) So what I am supposed to believe ? I have based my purchase decision under impression that EVGAs RMA policy regarding cooler replacements is not guaranteed within EU and also on the simple fact that EVGAs were out of stock everywhere.Not according to their own mods: http://www.evga.com/forums/tm.aspx?m=741202
