- 14 Sep 2012
Hello please refer to this post
ORIGINAL THREAD:
My first post I hope this is the right section, I'll get straight to the point.
Currently, My PC:
Asus P6T Deluxe
Intel Core i7 920 2.66Ghz (Nehalem)
Asus GeForce GTX 480 1536MB GDDR5
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz
Asus Xonar D2X 7.1 PCI-E Sound Card
2x Samsung 22" Monitor
I don't have a maximum budget but less then 2k would be great. I plan to pass this PC along to brother or my brother would buy the new PC.
It would need to be as fast or faster, It is used for Gaming, Programming and Trading. Not bothered about the Case, ideally something easy to manage and easy access to dust filters.
I require new Monitors of atleast 22" (1680x1050) bigger would be preferable, I would like a build that can handle 3, but 2 would be fine (if the cost is out of proportion). I do require a sound card for my headset. If my brother is the one to buy the PC he will need a small set of speakers.
Things I don't need:
Mouse, Keyboard, OS, Headset
I think I covered everything but if Not i will reply and edit this post to contain the updated information,
EDIT:
I guess I could use Onboard sound instead of Soundcard if that helps anything.
Thanks
Jamie
ORIGINAL THREAD:
Currently, My PC:
Asus P6T Deluxe
EDIT:
Thanks
Jamie
