- 29 May 2020
Hi !
I'm about to do my first build and as I intend to do some real overclocking, I made sure I got enough airflow in my case. I have 7 BeQuiet! Case Fan SilentWings 3 120mm PWM HighSpeed - BL070 fans and the two 140 mm fans of my CPU cooler : ZALMAN CNPS20X. My motherboard is the ASUS ROG Crosshair VIII Hero (wifi).
This is the breakdown of the Mobo for all-fan related stuff :
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
3 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x H_AMP fan connector
1 x W_PUMP+ connector
Now I know plugging in that many fans is a tricky one. Is it correct I shouldn't go higher than 1 A ?
I guess I need some sort of PWM fan hub (or more than one). Also wanted to add that I don't need anything RGB related hubs if that can make a difference.
What would be the correct setup and where do I have to plug the hub into ?
Thanks for your help...
I use a cheap Thermaltake 10-way PWM hub (Commander FP), cost less than a tenner and it works fine. There isn't currently anything 10-way I can see on OCUK, so I can't provide a link, I'm afraid. You'll have to do your own rummaging...
As I've said, exhaust fans only add noise. Sure, at same fan speed temps may be a couple degree cooler with exhaust fans, but in just intake fans' speed is increased to same noise level as both intake and exhaust make cooling is the same. The straighter the airflow the less turbulence / the less heated air mixes with cool intake airflow and the better the cooling temps. Best way to know is experiment and monitor the air temp entering cooler with a cheap wire lead remote sensor digital thermometer like basic indoor/outdor digital themometer, terrarium / aquarium or fridge remote sensor thermometer. Search for "wire lead remote sensor digital indoor/outdoor thermometer" or similar should find some for about seven quid, then set it up like at end of link below:
