resolution changes after reboot?
26 Nov 2009
Wales
Does anyone know how to resolve this issue. When i turn on my new comp it loads to desktop in 1024 x ??? resolution but it's set at 1360 x ???. But when i reboot it again it goes to the resolution i set it at. Also the graphics card fan goes really loud then silent then loud. Any ideas?
what is your system spec and what size monitor?
I have the titan sabre from overclockers
spec =
Graphics Card XFX ATI Radeon HD 4890 1GB GDDR5 Graphics Card
Motherboard Gigabyte GA-MA790X-UD3P AMD 790X PCI-Express DDR2 Motherboard
Processor AMD Phenom II X2 Dual Core 550 3.10GHz @ 3.30GHz Black Edition
Power Supply Corsair TX 650W ATX SLi Compliant Power Supply
Hard Drive Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache
Memory Corsair XMS2 4GB (2x2GB) DDR2 PC2-8500C5 TwinX Dual Channel
Processor Cooler AMD Approved CPU Cooler
Case Antec VSK 2000 Midi-TowerCase - Black
Warranty 1 Year Onsite Collect & Return Warranty
Sound Card High Definition 7.1 OnBoard Sound Card
Optical Drive LG GH22NS30 22x DVD±RW SATA Dual Layer ReWriter
and i have a 28in lcd monitor.
Many thanks!
Ye i know but i wanted to see if there was an option to stop it. As when i reboot straight after it stops. Seems odd to me
Nope cant stop it. My Ati does it aswell as did my last ati card going all the way to the 9800 pro.... I assume it will be power on test safety feature of sorts. For example if you dont here the fans prob broke lol (which is not uncommon) :D
Is that not because the drivers don't kick in untill windows start? So it runs full speed.
I think the only way round this is to fit a aftermarket cooler, will do the same only quieter.
As for your res problem, you tried a new mobo battery?
If you turn your pc off at the plug and the battery is dead it'll reset to default settings.
