- 13 Dec 2008
Wow, amazing case! only £40 or so! I'm buying this as my next case for sure. Great work with the pictures and the explanation.
This a much better case for £40 than the 900 for £70, id choose this even if they cost the same amout
The antec 900 is better made then the 300, the only improvements with the 300, it has cable management and dust filters, What anoyed me when working on the 300, you can only get the cables behind the tray at the bottom, but with the 900 you can get the cables behind the tray form the top or bottom, so I prefer my 900 over the 300.
This is gonna be my first case mod. Ill make a side window, paint the internals plack and add extra fans
why the hell has it gone up to £45?!
If putting together a decent spec, single GFX, HDD (or 2) rig & don't want the case to break your budget then the 300 is ideal. Outside that then this is really not for you. But against other cheaper cases it holds its own with enough fan mountings, bottom mounted PSU, etc & must admit it looks ok compared to the flashy offerings
When i get time at the weekend ill rehost all the pics.
