What drivers are you using? dvi cable? I don't see the option in my nvidia classic panel :/
Perhaps it's because I used the coolbits 2 .reg hack - might need to reinstall the drivers!
Here is what i see:
edit*
I found it
it's hidden away under device adjustments!
Edit 2*
Which scaling method do you use? when I select any other than the default my screen becomes all garbled up!
Here is what i see:
edit*
I found it
Edit 2*
